Hi, I’m under Linux (Ubuntu 20.04) and I’ve installed Java 11 :
$ java -version
openjdk version “11.0.11” 2021-04-20
OpenJDK Runtime Environment (build 11.0.11+9-Ubuntu-0ubuntu2.20.04)
OpenJDK 64-Bit Server VM (build 11.0.11+9-Ubuntu-0ubuntu2.20.04, mixed mode, sharing)
$ javac -version
javac 11.0.11
When I’m running Visual Paradigm, it’s openning but I get this message :
~/Programs/Visual_Paradigm_CE_16.3$ sh Visual_Paradigm
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by v.bys.dr (file:(…)/Programs/Visual_Paradigm_CE_16.3/Application/lib/vpplatform.jar) to constructor javax.swing.text.GlyphPainter1()
WARNING: Please consider reporting this to the maintainers of v.bys.dr
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
Is it a known bug, or would you have an idea from where the problem ?
Thank you very much for your answer ! I take this opportunity to ask you, is there any other way to launch Visual Paradigm in Linux, than this Terminal command, sh Visual_Paradigm ? I did’nt find any.
Hi Jick, thank you for your answer. This is ok, with both scripts Visual Paradigm is starting.
Keep me informed if there is any update about the Warning message, but in the meantime, as you told, it’s not harmful.
Best regards
