The new ‘Animacian’ feature within BPVA is really interesting, and a nice way of presenting process flows to groups of people.
While evaluating the different possibilities, I modelled an inclusive gateway, with 3 outgoing flows, of which always two should be followed (see image)
I would expect that based on this, Animacian identifies two possible paths… One path following the “>5000€” flow AND the default one, another path following the “<5000€” flow AND the default one. But Animacian gives three possible paths… Is this a bug, or is this how it is intended to be?
Sorry for my late response. We fixed the animacian problem for Inclusive Gateway, please run “BPVA Update” inside BPVA/bin folder to update to latest patch (sp1_20090805e or later) for the fix. You can refer to the following link for details about updating your product to latest patch:
BTW, updating to latest patch is supported in BP-VA 3.0 SP1. If you are running BP-VA 3.0 but not 3.0 SP1, please run “BPVA Update” to update to BP-VA 3.0 SP1 first, then update to latest patch.
This is not a correct behavior according to BPMN Spec 1.2 (9.5.3.2 Sequence Flow Connections) (BPMN 2.0 is not out yet). The representation on the original image concerns a default gate, not a “always use” gate, and a default gate is synonymous of “otherwise”. The spec says:
“If none of the ConditionExpressions for the Gates are evaluated as “TRUE,” then the DefaultGate
SHALL be chosen.”.
An “always use” gate would be a straight sequence flow. Animacian was right before, it is not now: it must show 3 different paths. And considering the original image the “default path” would be chosen only with an order of… exactly 5000 because the other paths are “>” and "<".
Thanks for your post. Our engineers is follow-up this issue and the bug fix will be available in BP-VA 3.2 (planned to be released in January 2010). I’ll let you know if there is any further news on this issue.
I would like to let you know that we fixed this problem in BP-VA 3.1 (you don’t need to wait for BP-VA 3.2), please update to latest patch (20091028e or later) for the fix. More details about latest patch can be found from:
Please let me know if there is anything we can help.
Of course, in this example, an actual process wouldn’t raise the 2 “monetary” paths at the same time because they are based on the same condition but the notions of Inclusive Gateway and “default” path (which means “otherwise”) are correctly handled now.
