Lets say I have class A and B and have an association between them as OneToMany… Specifying properly Multiplicity on both sides I get perfectly correct result in Java generated code…
lets say (simplified)
class A {
ArrayList bClasses = new ArrayList();
getters setters
class B {
A owner;
getters setters
But then a problem comes. I need to specify an annotation for generated List in class A.
like
@OneToMany(mappedBy=“owner”)
Specification of association does not have and Annotations Tab, so as I can see only way to go to create a linked attribute in general tab of association specification, which really looks like a solution, BUT. if I create an attribute with same name as association end name I get in resulted code straight property without an array:
class A {
B bClasses;
class B{
A owner;
if I choose different name I obviously get 2 attributes in class A, one from association with proper array but without annotation and second from attribute with annotations.
class A {
ArrayList bClasses =…
@myannotation
B bClassesAttribute;
I tried to give up association and just specify multiplicity for an attribute. It appears that generated code not depending on that at all its always generated code like:
ClassType propery;
although I think if I choose multiplication 0…x it should generate me a List or something…
Pls advise,
Yuri
