Hi VP,
In the DB-VA 3.1sp1 (VP_Suite_Windows_3_1_sp1_20071012) I’m evaluating I found this small bug in the section:
Oops… it should be:
Hi VP,
Oops… it should be:
[quote=distansia]Hi VP,
[/quote]
I forgot to say that this only happens when you use the SysCache setting with relative expiration when generating code. It is disabled by default.
Hi distansia,
Thank you for your post. We are now checking this issue. Will come back to you as soon as possible.
Hello distansia,
This problem has been fixed as well. Please download and install the patch that could be found at:
http://forums.visual-paradigm.com/posts/list/0/2595.html#19904
