Does the has xml file generated for it? If yes and if the xml file is being modified, you need to rebuild project (build does not work)
If the problem persists, I would like to ask you for the project and the generated files for checking the problem. Without them, it is hard to locate the problem. If you will send, please do not post here. You can send to my email address: jick@visual-paradigm.com
Restart the application
Note:
I am getting this error afterI replace the jar file with this new one.
java.lang.NoClassDefFoundError: v/icsa
at v.ipqd.f(:29)
at v.iazr.i(:30)
at v.RD.main(:5)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher.main(Unknown Source)
What could be the problem? Is my version different than yours or my trial license has expired? I have no way of checking the version number or my license since DBVA refuse to start and spit out this error instead.
I also tried to run ‘VP Suite License Viewer.exe’ to view my license but also get this error.
Ignore the above msg. Actually my jar file was corrupted, I redownloaded it and it works fine and dandy.
My problem now is my trial license has expired, lol, too bad.
I will have to convince my boss to purchase it to continue and I bet it is going to take some time. You know… getting management approval, etc… the usual red tape…
Your case is now available in Service Pack 2, which was released last Saturday. Since you were asked to use a patch, I would like to suggest you upgrade to the latest version, which is more stable than the patch.
To upgrade, please run the product updater inside the bin folder of VP Suite installation directory.
