I’ve begun migrating a Visual Paradigm server onto a new server and decommissioning the old one. I tried to take a backup of the ‘old’ server, and it is throwing a null pointer exception.
[2019/11/18 10:40:18] [warning] java.lang.NullPointerException
at v.uf.dz.a(:36)
at v.uf.dz.a(:18)
at v.ue.f.a(:22)
at v.ue.a.e(:187)
at v.aty.e.a(:284)
at v.aty.e.a(:94)
at migration.ExportVPServerMain.(:228)
at migration.ExportVPServerMain.main(:23)
I don’t seem to have permission to upload attachments.
[2019/09/06 15:56:14] [warning] [Key-Mapping] Duplicated key id: 837
[2019/09/06 15:56:14] [warning] [Key-Mapping] Duplicated key id: 838
[2019/09/06 15:56:14] [warning] [Key-Mapping] Duplicated key id: 988
[2019/09/06 15:56:14] [warning] [Key-Mapping] Duplicated key id: 1348
[2019/09/06 15:56:15] [warning] No JNI Library 8
[2019/09/06 15:56:33] [warning] Model not found (usually not a problem): i4RFD0qAUEB4ZQ8u, C:\VPServer_v13\webserver\webapps\ROOT\WEB-INF\repository\Projects\MariTime\201909\MariTime.v153.vpp, v.cbq.azp.l(:108)
[2019/09/06 15:56:33] [warning] generic shape refreshDiagramCategories no _configuration , shape dir : C:\VPServer_v13\webserver…\shapes
[2019/09/06 15:56:33] [warning] generic shape loadAllCategory no _configuration , shape dir : C:\VPServer_v13\webserver…\shapes
[2019/09/30 02:24:03] [message] Xmx: 910MB
[2019/09/30 02:24:03] [warning] Cannot read Product and Edition
[2019/09/30 02:24:28] [message] 02:24:28,857 WARN DerbyDialect:60 - HHH000430: The DerbyDialect dialect has been deprecated; use one of the version-specific dialects instead
[2019/09/30 02:24:34] [message] 02:24:34,009 WARN DerbyDialect:60 - HHH000430: The DerbyDialect dialect has been deprecated; use one of the version-specific dialects instead
[2019/09/30 02:24:35] [message] 02:24:35,332 WARN DerbyDialect:60 - HHH000430: The DerbyDialect dialect has been deprecated; use one of the version-specific dialects instead
[2019/09/30 02:24:35] [message] Your current DB version is: 20160105
[2019/09/30 02:24:35] [message] No any updates are available.
[2019/09/30 02:24:38] [message] ====== Start Floating License Server: 13.0 (20160103) ======
License Keys, count: 1
Visual Paradigm Enterprise Edition 13.0, qty: 7/7
valid
valid
valid
valid
valid
valid
valid
That kind of message chunk shows up sporadically in the logs. For example, it showed up in the section I included, but prior to that, it also occured on 2019/08/26
According to our engineers to problem you experienced was already fixed by the newer build of VP Server v13. Since download of old version software is only available to licensed user. Would you please send your license key to support-team@visual-paradigm.com so that we can send the server patch? Look forward to hearing from you.
