Thank you for the question and the answer to another post. I have forwarded your question to our engineers to follow up. When there is any update, I will let you know.
An update has been made in response to the case you reported. Here are the changes made:
The old constants below are deprecated:
AGGREGATION_KIND_NONE, AGGREGATION_KIND_AGGREGATION, AGGREGATION_KIND_SHARED, AGGREGATION_KIND_COMPOSITED
New constants are added:
AGGREGATION_KIND_shared, AGGREGATION_KIND_composite, AGGREGATION_KIND_none
Use the constants above as parameter of setAggregationKind. getAggregationKind() will return a value that’s either AGGREGATION_KIND_shared, AGGREGATION_KIND_composite or AGGREGATION_KIND_none
To get the change, update your installation to the latest patch build (16_3_20210540aa or higher). The article below shows you the steps:
Question: will this fix break if the plugin is installed in an older version of Visual Paradigm? If that’s the case I won’t be able to use the new constants for now.
