The Timer Event allows specifying only 2 types of element (timeDate and timeCycle) out of 3, and the missing one is timeDuration (see the excerpt from specification below). The “timeDuration” element is essential for correct implementation of timeouts (e.g. “in 2 hours”) and was introduced to avoid ambiguity of timeCylce, which allows specifying “every 2 hours” only. In our applications timeouts are most common use case for timer event and using timeCycle as a replacement does improve neither readability nor reliability of executable process. Do you have any plans to introduce full support for timer event as per BMPN 2.0 specification?
Thank you,
Alex
Here is the specification:
<xsd:complexType name="tTimerEventDefinition">
<xsd:complexContent>
<xsd:extension base="tEventDefinition">
<xsd:choice>
<xsd:element name="timeDate" type="tExpression" minOccurs="0" maxOccurs="1"/>
<xsd:element name="timeDuration" type="tExpression" minOccurs="0" maxOccurs="1"/>
<xsd:element name="timeCycle" type="tExpression" minOccurs="0" maxOccurs="1"/>
</xsd:choice>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
