Hello everybody,
I’am pretty new to buisness process modeling and working with Agilian.
I wanted to modell some process and add informations about the io-information needed and provided by Tasks. First i thought i could create a token (with attributes) at Start-Event wich folows the Sequence Flow get, changed by Tasks and so on, to nearly implement process like a state machine. Unfortuatly i found no way to do this.
Now i wanted at least to chart the input and output of Tasks, events, (gateways).
So in my example i got a process of user onboarding for an specific applikation. So nearly all input and output is some kind of user-contact information (while not beeing a data object). What is the best way to chart such information?
I wanted to do this with Input- Output-Set, but there seems no way to properly use these, as it would need a lot of copy and paste work to fill in dozens of single text lines. Same for the IO-Rules. Is there any way to globaly define Input and Output and just reference to this in IO-Set and IO-Rules?
I realy miss informations about IO and constraint usage in the UserGuide.
