I’ve got a problem with the code reverse functionality of VP. When I try to reverse my C++ code, an error dialog with the following message occurs:
Reason :
Output file from parsing source code does not exist.
/tmp/irTemp49663temp/ouf/index.xml
If the above file does not exist, please make sure there are execute permission to all files under the following directory:
/opt/VP_Suite3.4/bin/vp_windows
I am using Suse Enterprise 10.
Thx…
PS: All permissions are set properly. Used VP-Standard Edition with evaluation license.
It seems the problem related to some of the library required for reverse engineering not appear on your system. Can you try the following steps and see is it working?
rename the doxygen under VP Suite /bin/vp_windows to something else
The given link no longer works. Is there another place that doxygen can be downloaded from? Or can it be downloaded from anywhere?
Thanks!
[quote=Rain]Hello Lettort,
