I’m trying to test EH caching with a DBVA project. I turned on EH Caching and generated DB and code. When I try to run it, I get the following error:
java.io.NotSerializableException: com.dummy.test
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1156)
at java.io.ObjectOutputStream.defaultWriteFields(ObjectOutputStream.java:1509)
at java.io.ObjectOutputStream.writeSerialData(ObjectOutputStream.java:1474)
at java.io.ObjectOutputStream.writeOrdinaryObject(ObjectOutputStream.java:1392)
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1150)
but com.dummy.test was generated by DBVA. Its hbm file contains the line: (as it is read only)
I’m assuming that com.dummy.test must be serializable but since it’s generated by DBVA not sure why it’s not.
Any ideas?
