Can I modify the content of the deliverable generated from TOGAF ADM Guide-through? In particular I want to include external diagrams (diagrams created outside of the process) and tables created under other process steps. I also want to remove some content if possible.
Hi Ronnie,
Thank you for your post. The capability to tailor TOGAF ADM to fit different businesses’ needs is what we care about. TOGAF ADM Guide-Through allows you to modify work items by including your own steps. Besides, you can also customize the ADM deliverable through the intuitive, drag-and-drop report editor called Doc. Composer. The steps are as below.
- Open the phase in TOGAF ADM Guide-Through.
- In the ADM process map, right click on the icon of the deliverable that you want to customize, and then select Customize Deliverable… from the popup menu.
- In the Configure Deliverable window, click on Custom, and then click Create.
- This opens the deliverable in Doc. Composer where you can edit the document with drag and drop.
4.1 You can modify the text content.
4.2 Re-position content block with drag-and-drop.
4.3 Include content collected under the other part of the process.
Hope this helps. Feel free to let us know if you have any questions.
