I would like to know if I can have two installations of Visual Paradigm within the same MacOS user?
If so, how can I do it without using the same files in the Library/Application Support/VisualParadigm and Library/Application Support/Visual Paradigm folders across instalations?
I want to have access to different versions of Visual Paradigm in the same machine to support colleagues with different setups.
Thank you for your post. You can install different versions on the same machine but currently, we do not support changing the folder of application data. Sorry about this.
Is it still possible to download the Community version of VP 16.2? I could only download the trial version of VP 16.2 and this downgrade tutorial does not work there.
