Can no longer open VPOnline project in desktop
About 1 month ago I saved my project from the desktop app and checked it back in / committed it to VPOnline. This was all done in VPP17.1. This is the only project I have in VPOnline and the desktop app normally opens the first diagram as soon as I launch it, either the local working version (if not checked back in) or the server version.
Today I opened the desktop app and it failed to open my project. It is just stuck on the animated green diamonds (“Preparing”). I can view my project in VPOnline via a web browser and I see it is intact and correct. But the desktop app will not open any diagram in that project.
I am on a different WiFi network in a different city, but the connection speed is very good (faster than where I was before) and I have no trouble using any other apps. Not using a VPN.
I have logged out/in and even fully uninstalled/reinstalled the VPP app on my desktop. I can connect to my workspace and see the project, but none of the diagrams will open.
Please help me regain access to my diagrams.
Would you please send us your log files for checking? You can export them from the Help > About dialog of your VP application. Please send the whole zip to support-team@visual-paradigm.com for diagnosis. Thanks and look forward to hearing from you.
Logfile sent to the email you requested. Thank you.
Thank you for the quick fix on the backend that solved my issue!
It appears to be a specific issue with your Visual Paradigm desktop app’s connectivity. Since you’ve already tried basic troubleshooting, consider contacting Visual Paradigm’s support for specialized assistance in resolving this problem and regaining access to your diagrams.
It’s frustrating when a desktop app fails to open a project. Since you’ve tried basic troubleshooting, consider contacting the VPOnline support team for specialized assistance. They can provide guidance to resolve this issue and help you regain access to your diagrams.
Exactly the same thing is happening to me, any solution?
Hello everyone,
my problem was solving deleting files under %appdata%\VisualParadigm, and delete the JxBrowser folder under %localappdata%.
Ideally make a backup of the default workspace under %appdata%\VisualParadigm\ws or commit all your local changes.
Then startup VP application and select the workspace backup and open the project from Project → Open → Local File System. Or download your changes from scratch from the vpository.
Thanks to the vp support team (support-team@visual-paradigm.com) for their help.
