Hello this is the error i"m receiving…
Please your help
Test adapter connection failed!
java.lang.ClassNotFoundException: net.sourceforge.jtds.jdbc.Driver
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at v.xzg.i(:75)
at v.iejp.i(:23)
at v.iejp.f(:43)
at v.abf.run(:21)
Thank you for your post. Have you specify the adapter file? If yes, could you post a screenshot of your database configuration dialog box so that we can help identify what the problem is?
The adapter file is important for connecting to the database. After the proxy dialog shows, did you press OK to proceed? If yes, what happens next? If there is any error appear, please post here. Thanks a lot!
Jick,
After I test the connection, I press ok… It close the DB page, and then I can not see the DB connection in the main windows… But after some minutes I can view the DB tables, but I’m not able to query it aor code any think.
Sorry, but we were unable to reproduce this problem. Could you provide us with some screenshots showing the steps and results? Sorry for troubling you.
Here is the steps:
1- Open the program.
2-move to DB tab - have the image
3- open the DB configuration and set it - have the image and test it
4- press on OK and return to to the DB tab and there is no DB in the drop down menu
5- And I can not query or open any table info
