I have one question. I would like to use DB-VA SQL but I cannot connect to my database. I have switched on Remote Connections in my SQL Server (“Using both TCP/IP and named pipes”). After using jtds-1.2.jar I have the following error:
Test adapter connection failed!
java.sql.SQLException: Network error IOException: Connection refused:
connect
at
net.sourceforge.jtds.jdbc.ConnectionJDBC2.(ConnectionJDBC2.java:372)
at
net.sourceforge.jtds.jdbc.ConnectionJDBC3.(ConnectionJDBC3.java:50)
at net.sourceforge.jtds.jdbc.Driver.connect(Driver.java:178)
at org.orm.ertodb.DriverWrapper.connect(DriverWrapper.java:27)
at java.sql.DriverManager.getConnection(Unknown Source)
at v.iybj.i(:34)
at v.iybj.f(:43)
at v.yct.run(:21)
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(Unknown Source)
at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at
net.sourceforge.jtds.jdbc.SharedSocket.createSocketForJDBC3(SharedSocket.java:289)
at net.sourceforge.jtds.jdbc.SharedSocket.(SharedSocket.java:250)
at
net.sourceforge.jtds.jdbc.ConnectionJDBC2.(ConnectionJDBC2.java:297)
… 8 more
Test .NET connection failed!
java.lang.Exception: Wystąpił błąd podczas ustanawiania połączenia z
serwerem. Podczas łączenia się z programem SQL Server 2005 przyczyną tego
błędu może być fakt, że zgodnie z ustawieniami domyślnymi program SQL Server
nie pozwala na połączenia zdalne. (provider: Dostawca TCP, error: 0 - Nie
można nawiązać połączenia, ponieważ komputer docelowy aktywnie go odmawia.)
w System.Data.SqlClient.SqlInternalConnection.OnError(SqlException
exception, Boolean breakConnection)
w
System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject
stateObj)
w System.Data.SqlClient.TdsParser.Connect(Boolean& useFailoverPartner,
Boolean& failoverDemandDone, String host, String failoverPartner, String
protocol, SqlInternalConnectionTds connHandler, Int64 timerExpire, Boolean
encrypt, Boolean trustServerCert, Boolean integratedSecurity, SqlConnection
owningObject, Boolean aliasLookup)
w
System.Data.SqlClient.SqlInternalConnectionTds.OpenLoginEnlist(SqlConnection
owningObject, SqlConnectionString connectionOptions, String newPassword,
Boolean redirectedUserInstance)
w
System.Data.SqlClient.SqlInternalConnectionTds…ctor(DbConnectionPoolIdentity
identity, SqlConnectionString connectionOptions, Object providerInfo, String
newPassword, SqlConnection owningObject, Boolean redirectedUserInstance)
w
System.Data.SqlClient.SqlConnectionFactory.CreateConnection(DbConnectionOptions
options, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection
owningConnection)
w
System.Data.ProviderBase.DbConnectionFactory.CreatePooledConnection(DbConnection
owningConnection, DbConnectionPool pool, DbConnectionOptions options)
w System.Data.ProviderBase.DbConnectionPool.CreateObject(DbConnection
owningObject)
w
System.Data.ProviderBase.DbConnectionPool.UserCreateRequest(DbConnection
owningObject)
w System.Data.ProviderBase.DbConnectionPool.GetConnection(DbConnection
owningObject)
w System.Data.ProviderBase.DbConnectionFactory.GetConnection(DbConnection
owningConnection)
w System.Data.ProviderBase.DbConnectionClosed.OpenConnection(DbConnection
outerConnection, DbConnectionFactory connectionFactory)
w System.Data.SqlClient.SqlConnection.Open()
w NHibernate.Connection.DriverConnectionProvider.GetConnection()
I translate java.lang.Exception from Polish:
"Error when establishing connection with server - trying to connect to SQL
Server 2005. The reason of the error can be that according to default
setting SQL Server doesn’t accept remote connections. (TCP Provider, error: 0 - Connection cannot be established because destination computer refuses connection.)
Please help. Thank you.
RM
