I have TCP/IP enabled.
I know the connection string is right and working…
here is the log…
Can’t load Adapter Driver
java.sql.SQLException: Unknown server host name ‘.\sqlexpress’.
at net.sourceforge.jtds.jdbc.ConnectionJDBC2.(ConnectionJDBC2.java:364)
at net.sourceforge.jtds.jdbc.ConnectionJDBC3.(ConnectionJDBC3.java:50)
at net.sourceforge.jtds.jdbc.Driver.connect(Driver.java:178)
at org.orm.ertodb.DriverWrapper.connect(DriverWrapper.java:27)
at java.sql.DriverManager.getConnection(Unknown Source)
at v.iouq.i(:34)
at v.iouq.f(:43)
at v.vyu.f(:105)
at v.cwi.actionPerformed(:790)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.Dialog$1.run(Unknown Source)
at java.awt.Dialog.show(Unknown Source)
at v.wyf.show(:427)
at v.irfe.a(:735)
at v.irfe.show(:745)
at v.zsu.i(:54)
at v.ifex.actionPerformed(:246)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Caused by: java.net.UnknownHostException: .\sqlexpress
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at net.sourceforge.jtds.jdbc.SharedSocket.createSocketForJDBC3(SharedSocket.java:289)
at net.sourceforge.jtds.jdbc.SharedSocket.(SharedSocket.java:250)
at net.sourceforge.jtds.jdbc.ConnectionJDBC2.(ConnectionJDBC2.java:297)
… 63 more
No JNI Library 8
No JNI Library 8
No JNI Library 8
No JNI Library 8
No JNI Library 8
No JNI Library 8
