I have downloaded Smart Development Environment for Netbean 2.0 (VP_Suite_Windows_1_0_20041218.exe), but I could not get it installed. The installer kept telling me to define EXE4J_JAVA_HOME to point to JRE or JDK location.
Currently SDE for NetBeans does not support NetBeans 4.0, we are sorry that the system requirements in our website does not clarify this issue, we will correct this as soon as possible.
Thanks for your reply. However, I am not sure if you have understood my question as I said it issued the error message when I did install (check my attachment please). I mean it even have not checked out which netbeans version are installed. Therefore, this must be another problem. Moreover, I also tried the earlier version of netbeans but it was exactly what I have predicted: the same error message. So please check again if possible.
At least i found out why the SDE for NetBeans does not work, since i am also using version 4.0 (i can, at least, install SDE for NetBeans).
My question is very simple, can you give an estimate on how and when NetBeans 4.0 will be supported for the SDE ? I am currently using WASD 5.1, but i would like to use your software also ‘privatly’, by buying the modeller edition, and i can not use WASD at home…
Any hint would be usefulll.
I would also suggest that you add a meaningfull message in case you encounter platforms for which support is (not yet) available. In my case, when starting SDE for NetBeans, nothing seems to be happening, and i did not have a clue as to wether it had failed, was waiting for NetNeans to be started or …
hi! I’m having exactly the same problem (EXE4J_JAVA_HOME), besides, I’ve setup JAVA_HOME and it doesn’t work neither…
My setup is:
Windows XP Professional SP2, 256Mb ram
C:\j2sdk1.4.2_05 and Eclipse 3.0.1
I’ve tried the “No install” links, but they take me to… the user guide!!
