I have a question:
In my Sequence Diagram I accidentely created a frame around some methods and it automaticly expanded to include almost the whole SD! Now when I try to delete it, all blue blocks where my arrows go to and from disappear! How can I safely remove the frame without breaking the whole diagram?
I must say VP has me remaking lots of my diagram over and over again because of this kind of unexpected beheaviour and shaky undo functionality…
Hope there’s a simple workaround.
Thanks in advance,
Alex
I am sorry for any inconvenience the unexpected behavior of Frame may cause you and I have passed your problem on to our development team.
I just think of a workaround for you. You may try selecting all models within the diagram (Ctrl-A), and then deselect the Frame, and then right-click on the selection and choose Send to | New Sequence Diagram from popup menu. All selected models will be cloned and placed in a new Sequence Diagram. You can then work on with the ‘new’ Sequence Diagram.
I hope this can help you solve the problem temporary. We will investigate the problem and get back to you as soon as we can.
I have a question about your problem. Could you please let me know whether you were really creating a Frame or other models? The reason I ask is that a Frame would not include all LifeLines which result in including the whole diagrams. But for alt/loop, the messages would not be removed… To avoid fixing the wrong issue, I would first like to clarify with you what type of model that you have accidentally created on the diagram. Thank you very much.
The ‘Frame’ object is now (apparently) completely unlinked to the lifelines. Is this correct / by design?
If yes, then it’s fixed. Nice bug turnaround btw! Kudos to the development team!
Do you guys have a bugtracker? I have some more bugs if you’re interested
Yes, the containment behavior is changed to fix the problem. Thank you for your testing.
I regret that we do not have any bugtracker at the moment. But we would REALLY welcome any kind of bug report and suggestion. We appreciate if you submit your bug report at: http://www.visual-paradigm.com/support/bugreport.jsp
Our support team will get back to you as soon as they can.
It seems that tis issue has regressed as I have exactly the same problem in the latest version.
I must say it is concerning that the quality of this software seems to be questionable.
Thank you for your post and we are so sorry about the problem. It’s pretty strange because we have not been receiving similar bug report for years. Could you let me know about the steps? Besides, could you capture a screenshot to show the problem, and a screenshot to show the About window (Help > About VP-UML)?
Hi all,
I have the same problem with the sequence diagram. I suspect, but can’t be sure, that the problem occurred when I started to move the lifelines across to the right to make more room. It was after I did this that the frame jumped to the full size of the screen and will not let me delete it. If I click delete it removes everything other than the actor from the screen. I tried to click on the hotfix link in the forum but it appears it has been removed.
Appreciate a fix for this.
Steve
Mac OS/X 10.9
VP Version 10.2
Build 20131103
Sorry for our late response. The hot fix link actually is for a pretty old version, and this is why it no longer available by now. Our engineers suspect the problem us caused by some containment behavior for the frame. But after some test we still unable to repeat the problem. Would it be possible that you can share your diagrams to me so that we can find some hint about what is the problem? You can send me your project to support-team@visual-paradigm.com. Please include the URL of this forum post in your reply so that we can associate it with your case. Thanks and look forward to hear from you.
