Hello
I’ve tried to use Generate Code function from Model menu. everything seems to work fine but when I got the source files. All of them have error about can’t import org.orm.*.
I thought it came from some optional .jar was missing. Then I’ve tried to use an auto download from “Database Code Generation” dialog box and click at “Select Optional Jar” button.
I’ve got a connection problem. I’ve no proxy to connect to internet. I can update VSuite as normal tonight. So, i’ve no idea why I got Connection Problem. My SDE-Eclispe is version 20061004.
How can I download them separately from VP website? I think it’d included inside VP package. May be I’ve not seen the download link from VP website before.
I’ve reinstall the vpplatform.jar and run the VPSuite.sh for update. My splash screen show version 20061006p.
I’ve used Wizard from ORM menu and try to download the optional jar file again. No luck. It’s show…
Cannot download jar file: ORM Core
Please check proxy settingCannot download jar file: ASM bytecode library
Please check proxy settingCannot download jar file: ASM Attribute
Please check proxy settingCannot download jar file:ANTLR 2.7.6 RC1
and so on…
Btw, I’ve found these files inside $VPSuite/ormlib and $VPSuite/ormlib/optionaljar directories. When I use some neccessary files and repack with orm.jar, it’s work with my project.
What’s the different with the files that I’ve to redownload ? Do I have to redownload everytime I reverse database? (C’mon…)
I think it’d be packed within the VP SDE update. Or may be because you have licensing issue?
