I used the Visual Paradigm for UML 6.2 to draw an ERD diagram.
Then I tried ti generate SQL code (right click on the erd> Generate SQL…) BUT it didn’t work. The DDL tab is empty. It just generates DML.
I tried to generate code for an Oracle DB and THAT works. But it doesn’t for MySQL
The connection with the database is successful(I test it) and I used both Jconnector 3.1 and Jconnector5 but nothing changed.
I would appreciate any help on this, thank you very much.
