Hello
is it possible to change all varchar(255) type in an Entity to nvarchar(255)?
is is possible to change the default behavior: String to varchar(255)?
Hello
Hi user,
Thanks for your post. I’ve passed your issue to our engineers to see if we can develop a plugin to help you change the column from varchar(255) to nvarchar(255). If there is any feedback, I’ll come back to you.
We are sorry that currently setting default type for column is not supported, but we will consider it.
Hi user,
I would like to let you know that we developed the plugin already, please find it attached below. To deploy the plugin:
Please take a look at the attached image as an example of how to use th plugin. If you want to change all varchar(20) to varchar(255), you need to set any one of the column to be varchar(255) first (the plugin requires to base on existing column). Then, right-click on varchar(255) column, select “Change specified column type to this column”, a dialog will show for entering the “type” (in this example, enter “varchar(20)”). Click OK to confirm, all “varchar(20)” columns will then be changed to “varchar(255)”
Note: on the input dialog, if user do not specify the length (enter “varchar” without “(20)”), all “varchar” columns will be varchar(255)
Hope this plugin helps. If you need any further assistance, please feel free to ask.
com.vp.plugin.sample.changecolumntype.zip
