Hi!
There are some problems with copy functionality(version 6.0 Build sp1_20070316).
1)If the class is stereotyped and the presentation is set to robustness analysis icon, then attribute and operation compartments arn`t copied to JPG/EMF/OLE, only the stereotype icon and class name.
For example class with stereotype <> and some attributes/operations in the vp looks correctly, but after copy/paste through JPG/EMF/OLE the compartments have disappeared.
2)The same problem is with template class - class with template parameters. After copy/paste through JPG/EMF/OLE the parameter part disappear.
3)If the class is stereotyped with stereotype for which the icon path is given(custom picture), then after copy/paste through EMF the icon picture have disappeared(blank). This is in both case, the robustness analysis icon and stereotype icon.
All these points works correctly with copy witih VP-UML
At this moment, i solved it with printscreen, but maybe this info is useful for VP-UML. From changelog i saw that you are fixing these type of problems.
If you need some sample for repeating the problem, let me know, i`ll send them.
Thanks, for VP-UML!
