ClassNotFoundException: org.orm.cfg.JDBCSettings
Hi.
I have installed SDE for Eclipse 6.2 in Eclipse Indigo 3.7 without problems. However, when i start the IDE with the link created appears the next error in the “vp.log” file and it is impossible to work:
[Thu Oct 04 16:39:39 CEST 2012] [message] Exception in thread “Thread-17”
[Thu Oct 04 16:39:39 CEST 2012] [message] java.lang.NoClassDefFoundError: org/orm/cfg/JDBCSettings
[Thu Oct 04 16:39:39 CEST 2012] [message] at v.igq.(:49)
[Thu Oct 04 16:39:39 CEST 2012] [message] at v.yhz.(:150)
[Thu Oct 04 16:39:39 CEST 2012] [message] at v.ccmz.a(:113)
[Thu Oct 04 16:39:39 CEST 2012] [message] at v.ccmz.a(:54)
[Thu Oct 04 16:39:39 CEST 2012] [message] at v.zdk.J(:1128)
[Thu Oct 04 16:39:39 CEST 2012] [message] at v.zdk.o(:982)
[Thu Oct 04 16:39:39 CEST 2012] [message] at v.xac.(:2035)
[Thu Oct 04 16:39:39 CEST 2012] [message] at v.xac.(:1111)
[Thu Oct 04 16:39:39 CEST 2012] [message] at v.alss.run(:107)
[Thu Oct 04 16:39:39 CEST 2012] [message] Caused by: java.lang.ClassNotFoundException: org.orm.cfg.JDBCSettings
[Thu Oct 04 16:39:39 CEST 2012] [message] at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
[Thu Oct 04 16:39:39 CEST 2012] [message] at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
[Thu Oct 04 16:39:39 CEST 2012] [message] at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
[Thu Oct 04 16:39:39 CEST 2012] [message] at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
[Thu Oct 04 16:39:39 CEST 2012] [message] at java.lang.ClassLoader.loadClass(Unknown Source)
[Thu Oct 04 16:39:39 CEST 2012] [message] … 9 more
What is causing the error?
Thanks in advance.
Can you try right click on the Java project inside Eclipse’s Package Explorer and select Open SDE-EC to see is it work? BTW, may I know what is the build number of SDE you using? or what is the file name of the installer file you used? Thanks!
Rain Wong
If I open Eclipse and I do right click on Java project and select “Open SDE-EC” as if I open the shortcut created has the same behavior: appears the text “Starting SDE SE-EC…” in the bottom bar and Eclipse gets blocked.
Eclipse:
Release 3.7.2
Last revised Feb 7, 2012
Visual Paradigm:
installer: VP_Suite_Windows.exe
You can view the SDE build number in the “vp.log” file:
[Fri Oct 05 11:32:33 CEST 2012] [warning] Failed to read registry and set clear type.
[Fri Oct 05 11:32:33 CEST 2012] [message] [ Fri Oct 05 11:32:33 CEST 2012]: Start Smart Development Environment Standard Edition for Eclipse [SDE SE-EC]: 6.2 (20110623)
[Fri Oct 05 11:32:37 CEST 2012] [message] Exception in thread "Thread-28"
[Fri Oct 05 11:32:37 CEST 2012] [message] java.lang.NoClassDefFoundError: org/orm/cfg/JDBCSettings
[Fri Oct 05 11:32:37 CEST 2012] [message] at v.igq.<init>(:49)
[Fri Oct 05 11:32:37 CEST 2012] [message] at v.yhz.<init>(:150)
[Fri Oct 05 11:32:37 CEST 2012] [message] at v.ccmz.a(:113)
[Fri Oct 05 11:32:37 CEST 2012] [message] at v.ccmz.a(:54)
[Fri Oct 05 11:32:37 CEST 2012] [message] at v.zdk.J(:1128)
[Fri Oct 05 11:32:37 CEST 2012] [message] at v.zdk.o(:982)
[Fri Oct 05 11:32:37 CEST 2012] [message] at v.xac.<init>(:2035)
[Fri Oct 05 11:32:37 CEST 2012] [message] at v.xac.<init>(:1111)
[Fri Oct 05 11:32:37 CEST 2012] [message] at v.alss.run(:107)
[Fri Oct 05 11:32:37 CEST 2012] [message] Caused by: java.lang.ClassNotFoundException: org.orm.cfg.JDBCSettings
[Fri Oct 05 11:32:37 CEST 2012] [message] at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
[Fri Oct 05 11:32:37 CEST 2012] [message] at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
[Fri Oct 05 11:32:37 CEST 2012] [message] at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
[Fri Oct 05 11:32:37 CEST 2012] [message] at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
[Fri Oct 05 11:32:37 CEST 2012] [message] at java.lang.ClassLoader.loadClass(Unknown Source)
[Fri Oct 05 11:32:37 CEST 2012] [message] ... 9 more
Thnaks. Best regards,
Xavi Folch
