I have a problem with Typedef class for base class generated in one C++ file.
Class C in class A generates something like this:
#ifndef A_H
#define A_H
namespace nsTest {
* a
class a
private:
int attribute;
public:
void b();
#ifndef C_H
#define C_H
* c
class c
#endi
If class B has a Typedef stereotype, then the code-gen produces error: [Error] Fail to generate code. nsTest.png
For the inner class problem. the issue was identified and fix will be available soon.
For Typedef problem, it caused by missing define type in typedef, the fix will generate type as “int” when undefined. Please follow these steps to define type for typedef:
ensure programming language is C++ (under Window > Configuration > Configure Programming Language…)
open specification dialog for b, select “Class Code Details”, define Type property.
I would like to let you know the fail to generate code problem has been fixed. Please update the software to latest patch build (sp1_20170815be or later) to get the problem fixed. Details about update to latest patch can be found at
Please note that in you model you have the operation and typedef having the same name, and you will need to rename either one of it in order to have the code being generated.
