I’m using eclipse 2.1.3. I have installed Visual Paradigm SDE Ver 1.1 Community Edition (Smart Development Environment Community Edition for Eclopse 1.1) as eclipse-plugin.
Is in the version of SDE I’m using the feature “Update UML Model” (it does mean “generate UML-Diagramm”) enabled? I can’t use this very useful feature. Or is this feature not available for community edition?
The only benefit of having the Community Edition of the SDE’s is to be able to view the UML Diagram and the code at the same time - there are no code engineering/re-engineering tools. If you need these tools, then you will need to get the Professional Edition. You can try out the Professional Edition for 30 days if need be.
