Hello !
I’m trying to generate code by command line.
Using InstantGenerator.bat, I get “No element is selected”, and no code is generated.
The documentation does not give any indication of how to select elements to generate. The vpp I use is an empty project in which an XMI has been (successfully) imported.
Using JavaCodeSync.bat, I cannot specify the special generation template I wish to use.
Generation through the UI works fine, but I need it to be automated.
Does anyone have an idea of why it does not work ?
