Trying to connect to 2016 SQL Server database in the Enterprise.
2 issues:
Where is the file installed for the “Microsoft SQL Server (JTDS Driver)” what is the full filename and path for this driver?
I did not find this driver file after searching all of the subfolders in C:\Program Files\Visual Paradigm 16.0
I was able to download a jtds.jar file and try and use it to connect to the database. That connection did not work.
Here was my connection string:
jdbc:jtds:sqlserver://DBSERVERNAME:PORTNUM /DBNAME
I made proper substitutions for the Servername, portnumber & DBName.
I got your message, it treated as HTML so you need to use Preformatted Text or prepend with 4 spaces.
You can click the download button and it’ll show as <<jTDS 1.3.1>>.
It seems that you’re using Window Authentication, please read this knowhow for details of using SQL Authentication and Windows Authentication:
If still fail, please try Test Connection, it’ll show error dialog if failed, please click Show Details and attach the details.
Here is what I have tried so far (with substitutions where needed)
1st Option
Driver MS SQL Server (jTDS Driver)
Driver File \Desktop\jtds.jar (downloaded the driver)
Connection URL:
Hostname <OurServerName>
Database Name <OurDBName>
User <my Windows login> pw <my windows pw>
2nd Option
Connection URL
jdbc:jtds:sqlserver //<servername>/<dbname>
