I’m evaluating this software. I love everything except connecting to SQL Server isn’t as easy as I thought.
I selected
“.NET” as Language
MS SQL Server
Version: 2008 or higher
Driver: MS SQL Server
Adapter file: jTDS 1.3.1 << this is the only selection I have tho
I’m trying to use Windows Authentication, but I got below error message
java.sql.SQLException: I/O Error: SSO Failed: Native SSPI library not loaded. Check the java.library.path system property.
at net.sourceforge.jtds.jdbc.TdsCore.login(TdsCore.java:654)
at net.sourceforge.jtds.jdbc.JtdsConnection.(JtdsConnection.java:371)
at net.sourceforge.jtds.jdbc.Driver.connect(Driver.java:184)
at org.orm.ertodb.DriverWrapper.connect(DriverWrapper.java:27)
at v.aam.c.a(:66)
at v.aam.c.b(:78)
at v.aam.av.run(:25)
