I’m having a consistent problem on my laptop with both the No-VM install-anywhere version of VP and the no-install version. They both install and run just fine, and show the “loading” splash screen, but the progress bar gets about 3/4 of the way across and freezes. CPU usage goes to 0% and the window will sit there until I kill it.
I attached my vpuml.log file.
My environment:
Redhat 9.0 with all current errata on a Dell Latitude CPx laptop
java -version:
java version “1.4.1_02”
Java™ 2 Runtime Environment, Standard Edition (build 1.4.1_02-b06)
Java HotSpot™ Client VM (build 1.4.1_02-b06, mixed mode)
I got the no-install version running on my XP box without any trouble, although I did have to use the no-install rather than the no-VM version (my XP box also has Java 1.4.1_02 on it already). I notice the program GUI comes up when the progress bar is at the same place it freezes on my laptop. Any advice would be much appreciated ![]()
Just a few words of praise:
I tried Objecteering, ArgoUML, UML Pad, and Visual Paradigm, and VP was the only one that had the feature set I needed and was also usable enough to lay out the complex project I’m working on. Now if only I could get it running on my laptop, I’ll be in great shape ![]()
Thanks in advance.
vpuml.log
