I am currently evaluating VP for UML 6.2 and am having the following problem. Whenever i seem to work in the UI section the application will crash after 30 minutes or so. when i try and open the application again and load the file i was working on it says it is corrupt. The first time this happened I was able to import all the objects into a new file however it has happened again this has not worked. I am running Vista 64. If anyone could help it would be greatly appreciated.
I would like to have an online meeting with you to diagnose the problem. Can we schedule a time to have the meeting?
Rain Wong
Hi Rain,
Thanks for your quick response and interest. I noticed I had an install of 6.1 still on my computer so I uninstalled it along with 6.2 and then reinstalling 6.2. Everything now seems to behaving itself so I guess the previous install was the problem.
Hi allware,
Thank you for your reply. So do you experience the same problem since you’ve found the solution? If yes, please let us know. Thank you.
