I’m using the document generator on an entity relationship diagram. Both the “Data Dictionary” and “Data Dictionary 2” templates sort the column names alphabetically. Is there a way to display them in the same logical order in which they appear in the tables?
You can right click on either Data Dictionary or Data Dictionary 2 template to duplicate it, after that edit the template by adding under the iteration of the DBColumn Iteration block. After that the order of columns will be same as in your diagram.
