I work on WinXP Pro SP2, j2sdk 1.4.2_10, eclipse 3.1.2, MySQL 5.0 and DBVA-EC 3.1 Java
I have tried to follow the flight-example from the programmers guide. But after drawing the ERM and generating the Class-diagram, I now cannot generate neither database DDL nor Java code.
In the vp.log I found a java.lang.NullPointerException - does that mean, I forgot to specify something?
Please help me
Thanks in advance
Georg
This is the content of my vp.log:
[ Thu May 04 07:42:55 CEST 2006]: Start DB Visual Architect Java Edition for Eclipse [DBVA Java-EC]: 3.1 (sp2_20060422)
Exception occurred during event dispatching:
at v.iiez.A(:38)
at v.iiez.(:30)
at v.rge.i(:35)
at v.irdx.f(:345)
at v.irdx.i(:42)
at v.hal.actionPerformed(:172)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$ForwardActionEvents.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.Dialog$1.run(Unknown Source)
at java.awt.Dialog.show(Unknown Source)
at v.uyt.show(:427)
at v.ioba.a(:735)
at v.lcp.a(:148)
at v.ioba.show(:745)
at v.ynq.i(:47)
at v.xic.f(:100)
at v.yii.o(:50)
at v.inwc.z(:191)
at v.itbn.P(:244)
at com.vp.vpsde.ec.actions.ORMGenerateDatabaseAction$1.run(:18)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
I’m using WinXP SP2 too and I got a similar Error while writing down the DDL-File for MySQL.
When I choose “Generate SQL” in the context-menu of a table, I can’t see anything in the popup-window - everything is grey. When I delete some tables or associations, it works fine.
Here is the error-log:
[Fri May 05 15:43:01 CEST 2006]: Start DB Visual Architect PHP Edition [DBVA PHP]: 3.1 (sp2_20060422)
at v.snv.i(:27)
at v.xic.f(:209)
at v.irdx.f(:381)
at v.irdx.i(:42)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at v.uyt.show(:427)
at v.ioba.a(:735)
at v.ynq.i(:47)
at v.xic.f(:100)
at v.yii.o(:50)
at v.wst.b(:1306)
at v.ithp.i(:2225)
at v.mqp.r(:144)
at v.hze.actionPerformed(:63)
at javax.swing.AbstractButton.doClick(Unknown Source)
at com.jidesoft.plaf.vsnet.VsnetMenuItemUI.doClick(Unknown Source)
at com.jidesoft.plaf.vsnet.VsnetMenuItemUI$MouseInputHandler.mouseReleased(Unknown Source)
This problem is fixed in the latest release. Please perform an update to advance to the latest build. You can update the VP Suite via the updater at $vp-suite-install-dir/bin/VP Suite Update 2.2.exe
