Is DBVA-EC 4.2 compatible with Eclipse Ganymade ?
Hi Santm,
Thanks for your post. Yes, DBVA-EC 4.2 supports Eclipse Ganymade (3.4).
BTW, currently we have DBVA-EC 5.0 SP1, I recommend you upgrade to DBVA-EC 5.0. If you purchased DBVA-EC but not sure whether you are entitled to upgrade to DBVA-EC 5.0, please contact our support team at the following link:
http://www.visual-paradigm.com/support/
I actually tried the same and was able to install DBVA-EC 4.2 with own Eclipse 3.1 version on Eclipse Ganymade. What I observed is that while loading the workbench it gives a warning that some workbench setting cannot be used. I can see that all modeling menus are coming and I am able to create ORMs as well.
While generating the code the Message window shows that code is generate but when I see my project explorer I dont find it anywhere. In fact , I initially thought that it is SVN problem and installed svn in that workspace. However, DBVA-EC being packaged with older eclipse 3.1 , couldnot allow svn 1.4 install on it.
Next, I installed DBVA-EC again on our eclipse 3.4 and was able to install svn on it. However, I am still unsbale to find generated code (POJOs and HBM) .
Could you please advice what can be the problem?.
Hi Santm,
Thanks for replying. I can installed DB-VA 4.2 SP1 on Eclipse 3.4.2 and works without any problem even if generate code (I can see the source appears under src node). I used the latest build of DB-VA 4.2 SP1, which you can download from the following link:
Could you please install the latest build to see if you still have the same problems?
I linked one of the project directory as source and it worked.
Hi Santm,
It’s great that you solved the problem! Have a nice day!
Regarding DBVA-EC 5.0 SP1 upgrade, Could you please highlight some features that provide it more reasonable to move to that version ?
Hi Santm,
Thanks for replying. From DB-VA 4.2 to DB-VA 5.0 SP1, we support reference to element in external project, Table per Concrete Class inheritance strategy, export/import Excel of diagrams, target placement of classes when sync class diagram and ERD, etc. You can get details about the new features and enhancements from DB-VA 4.2 SP1 to DB-VA 5.0 SP1 from the links below:
http://www.visual-paradigm.com/news/vpsuite32sp1/dbva42sp1.jsp
http://www.visual-paradigm.com/news/vpsuite33/dbva43.jsp
http://www.visual-paradigm.com/news/vpsuite33sp1/dbva43sp1.jsp
http://www.visual-paradigm.com/news/vpsuite34/dbva44.jsp
http://www.visual-paradigm.com/news/vpsuite34sp1/dbva44sp1.jsp
http://www.visual-paradigm.com/news/vpsuite34sp2/dbva44sp2.jsp
http://www.visual-paradigm.com/news/vpsuite40/dbva50.jsp
http://www.visual-paradigm.com/news/vpsuite40sp1/dbva50sp1.jsp
You can also download the evaluation version from our website ( http://www.visual-paradigm.com/download/download.jsp?product=vpsuite ) to have a test with DB-VA 5.0 SP1 before upgrading. Hope these help.
