hi there,
i’ve downloaded the trial version of db visual architect, and choose the eclipse plugin version for osx.
When running the installer, there’s no option for the eclipse plugin, just some other ides.
Is dbva not supported for a osx/eclipse setup ?
Hi Pulse00,
Thanks for your interest in our product. We are sorry that the SDE for Eclipse is not available on Mac OS X at the moment since currently Mac does not enhance the support of SWT, which affecting our integration.
If you really want to run VP with Eclipse, you can consider the IDE integration in VP-UML Professional Edition (or above), which also supports database modeling.
More details about the Eclipse integration by VP-UML on Mac OS X can be found at http://oldresources.visual-paradigm.com/vpsuite2.3sp1/eclipse_integration_on_mac.html
** To make sure the integration runs smoothly, please edit the eclipse.ini file (inside Eclipse.app/Contents/MacOS/) and add a line “-XX:MaxPermSize=256m”
If there is any further inquiry, please do not hesitate to ask.
thanks for the info, i’ll simply go for the standalone version.
Hi Pulse00,
You are welcome.
