Hello. I have been using DBVA on OS X 10.5 for several months. Yesterday I upgraded to OS X 10.6 (Snow Leopard). DBVA will no longer start. The splash screen is displayed and the massage states ‘Initializing Environment’. The application never starts and the splash screen does not disappear.
It seems the build of DB-VA you using is a bit out-dated. We fixed some related issue on the latest SP1. Can you upgrade to SP1 and see is it work? You can run the VP Suite Update to update DB-VA to SP1 build. Please let me know it works or not. Look forward to hear from you.
Hello. I am unable to connect to a SQL Server database using this version. Here is the stack trace. I am able to connect using a different product.
v.bvy: Connection timeout!
at v.gsb.i(:62)
at v.spm.i(:713)
at v.rux.actionPerformed(:673)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2028)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2351)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:236)
at java.awt.Component.processMouseEvent(Component.java:6348)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
at java.awt.Component.processEvent(Component.java:6113)
at java.awt.Container.processEvent(Container.java:2085)
at java.awt.Component.dispatchEventImpl(Component.java:4714)
at java.awt.Container.dispatchEventImpl(Container.java:2143)
at java.awt.Component.dispatchEvent(Component.java:4544)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4618)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4282)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4212)
at java.awt.Container.dispatchEventImpl(Container.java:2129)
at java.awt.Window.dispatchEventImpl(Window.java:2475)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:635)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:205)
at java.awt.Dialog$1.run(Dialog.java:1045)
at java.awt.Dialog$3.run(Dialog.java:1097)
at java.awt.Dialog.show(Dialog.java:1095)
at v.imfn.show(:427)
at v.fyff.y(:740)
at v.fyff.show(:750)
at v.iupi.i(:80)
at v.muv.f(:575)
at v.ioqh.actionPerformed(:689)
at v.fyff.y(:740)
at v.kbq.i(:50)
at v.ivgn.f(:135)
at v.kip.o(:436)
at v.fgab.e(:1865)
at v.feys.i(:3661)
at v.icye.r(:165)
at v.idzy.actionPerformed(:61)
at javax.swing.AbstractButton.doClick(AbstractButton.java:389)
at com.apple.laf.ScreenMenuItem.actionPerformed(ScreenMenuItem.java:95)
at java.awt.MenuItem.processActionEvent(MenuItem.java:627)
at java.awt.MenuItem.processEvent(MenuItem.java:586)
at java.awt.MenuComponent.dispatchEventImpl(MenuComponent.java:317)
at java.awt.MenuComponent.dispatchEvent(MenuComponent.java:305)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:638)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Thanks for replying. Do you mean updating to latest build solved the start problem of DB-VA?
For the SQL Server connection problem, please refer to the following resources page and see if you can solve the connection problem:
Hope this helps. If you still cannot connect to SQL Server, please attach a screenshot of the Database Configuration dialog and the vp.log file (you can find it from VPSuite/bin folder). Thanks in advance!
