if we check the option in the teamwork client … project files are still there after logout … any ideas ??
thank you
thank you
Dear cpasedag,
Could you post the log files for us to check this problem? You can find the vp.log file under:
Client:
$vp-suite-install-dir/bin
Server:
$temwork-server-install-dir/bin
here they are …
Hi cpasedag,
Thanks for the logs. We are going to setup an environment to test this issue. Meanwhile, I do have another question - Except that the project file remains there, are there any other drawbacks? Let say, are you able to commit/update project?
currently we have no other problems with the teamwork server …
thanks for your quick response
christian
Hi christian,
We can repeat the problem. In fact, the option does not seems to be recorded - It became unchecked after reopening the dialog box.
We are going to fix this problem. Once this is fixed, I will let you know.
HI christian,
The reported is fixed. Please download the patch at:
http://files3.visual-paradigm.com/200611/Patch/5-3-3_sp3_20061117e/vpplatform.jar
To install the patch:
Please feel free to let me know if there are any questions.
Error message after replace and restart:
Java.lang.ClassNotFoundException: RV
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher.main(Unknown Source)
Appears when starting BP-VA and VP-UML …
Hi cpasedag,
Sorry about this. May I know how large the vpplatform.jar is? I doubt if it is corrupted.
it is 49,7 MB (52.146.518 Bytes)
Hi cpasedag,
I would like to have an online meeting with you to take a look at the problem. I have sent you the information about the meeting. I look forward to hearing from you.
Hi cpasedag,
I would like to let you know that a new version is released. Since you were asked to install a patch, I suggest you advance to the latest complete release, which can be downloaded at:
http://www.visual-paradigm.com/download/download.jsp?product=vpsuite
