during my modelling I created a Sub-Process and added an existing Diagram as Child to the Sub-Process. Now I need to detach the child from the parent. I already tried the two-step procedure as outlined in the documentation. It did not work for me. If I click on the little cross in the Sub-Process-Element, the “detached” child always shows up again.
Does anyone have an idea how to remove the link between the parent and the child?
Thanks in advance.
Daniel
Hi Daniel,
Thanks for your inquiry. You can open Model Explorer and locate the sub-process from the tree, expand the sub-process and you will see its sub-diagram and children. Please right-click on the sub-diagram and select Detach from Parent in the popup menu.
Hope this helps. If there is any further inquiry, please let me know.
P.S. when you want to locate the sub-process in tree in Model Explorer, you can right-click on the sub-process and select Selection > Select in Tree.
