I’m using SDE-EC and Eclipse.
In SDE-EC, I created a class diagram, and wrote some HTML documentation for it. Then I updated code to get java code of the class, the problem was that the comments (generated from documentation) in java code was plain text with no html tags. :?
Then I manually added html tags for the comments, then updated uml model, the problem was that the documentation (generated from comments) for the class diagram in SDE-EC became plain text.
Is there a way to synchronize both environments?
If there’s no way, then I’d propose it as a feature request.
Thanks!
