Doc Template for traced Requirements
Hi everybody.
I have a lot of use case diagrams. Each use case has several requirements associated with a trace relationship. In a generated document (doc composer) i want to plot all requirements for the respective use case in a table. Is this possible?
Thanks a lot
You can customize a Template XML to retrieve the requirement from use case.
<?xml version="1.0" encoding="UTF-8"?>
<ElementBaseInitiationBlock>
	<Inline template="General/Element Basic"/>
	<!-- Check whether connects with Requirement by trace-relationship -->
	<ForEachRelationshipConditionChecker>
		<Conditions>
			<ValueChecker property="stereotypes" value="trace"/>
			<ToElementConditionChecker>
				<ValueChecker property="modelType" value="Requirement"/>
			</ToElementConditionChecker>
		</Conditions>
		<Text style="@heading+">Traced Requirement(s)</Text>
		<ParagraphBreak/>
		<!-- For-Each the trace-relationships -->
		<ForEachRelationship>
			<Conditions>
			</Conditions>
			<!-- Get the Requirement -->
			<ToElement>
				<!-- Show Requirement by its "Basic" template -->
				<Inline template="Basic"/>
			</ToElement>
		</ForEachRelationship>
	</ForEachRelationshipConditionChecker>
</ElementBaseInitiationBlock>
Sample:
