SDE 4.2 (Evaluation version)
I could not find the Dockable User Interface of SDE (UML tree pane, Diagram Navigator). How could I show it again? Yesterday I could see it, but today I did not.
Hi trialtrial2007,
Thanks for your post. As I’m not sure which IDE are you using, I’m going to use SDE for Eclipse (SDE-EC) as an example for you to refer to (similar steps are applicable on other IDE to start SDE):
In order to start SDE-EC, you need to have an existing project in Eclipse first. Then right-click on the project and select Open SDE-EC in the popup menu (please refer to the attached image).
If there are any problems, please let me know.
Hi LilianWong,
Thank you for your answer. I found where to reshow “Diagram Navigator” in VS2005.
VS2005’s Menu > View > SDE-VS Windows > Diagram Navigator (Voila!)
Best regards.
Hi trialtrial2007,
Thanks for replying. I’m glad that you have found the solution.
If there is anything I can help in the future, please do not hesitate to contact me again.
