OS : XP home edition
ECLIPSE with VP plugin (community ver.)
After creating the actors and use cases in the textual analysis
When I try to drag n drop them from the diagram tree in the use case diagram , it does not work .
Regards
Regards
Hi Ahmed,
I realise that this post will be too late for you, but other users may come across this problem. The solution to the problem is to generate the objects, this is explained at:
http://www.visual-paradigm.com/textualanalysis/index.html
I hope this helps other users.
All the best
Lew
