I created an LDM ER diagram for a data warehouse. The entity is named D Country. I created the PDM using a translation table to translate the field names and entity names (I converted to lower case and underscores).
Now I used few such entities as conformed dimensions and copied them to another LDM ER diagram in the same folder. When I create the PDM, it creates duplicates for the conformed dimensions. I see that the entities are now no longer considering the translation table for the entity names in spite of specifying to use the translation table. So I am getting in PDM a table called d_country as desired and a duplicate “D Country” as well. Is this a bug?
Thanks for your post. By “translation table”, do you mean the Abbreviation feature? When you synchronize the second logical data model to a physical ERD, did you select the same Abbreviation Set? According to our testing, no matter the Abbreviation Set has been set or not, it will not re-create a new entity. It will just modify the name of the existing entity… By the way, how did you copy the entities to the second logical ER model?
SM : Yes
SM : Yes
SM: Did you first create star 1 LDM, convert to PDM diagram 1. Then create star 2 LDM by copying few dimensions and adding new fact, then create the PDM diagram 2. My issue is manifested in diagram 2 and not diagram 1
SM: I created a new empty LDM diagram in same project. Then I copied the conformed dimensions by selecting and dragging them to the new,empty diagram (diagram #2). So now these conformed dimensions are available in both LDM diagram #1 and LDM diagram #2
Thanks for your reply. I have captured a video to show you my steps, could you take a look and see if I am correct? Please visit the URL below to watch the video:
As you can see, there is only one d_country even though the synchronization was made from two logical ERDs.
Jick, thanks. You should have the d country copied in another ldm diagram. So in effect there should be 2 ldm diagrams converted to 2 pdm diagrams. Currently you only have 1 ldm diagram
I have created another logical ERD at about 00:55. BTW, do you have any video capturing tool installed and if yes, could you capture a short video to show the steps? Many thanks.
