Hi i am Joe
could u help on this issue…
Error while informing user about event loop exception:
org.eclipse.swt.SWTError: No more handles
at org.eclipse.swt.SWT.error(SWT.java:3375)
at org.eclipse.swt.SWT.error(SWT.java:3272)
at org.eclipse.swt.SWT.error(SWT.java:3243)
at org.eclipse.swt.widgets.Widget.error(Widget.java:432)
at org.eclipse.swt.widgets.Control.createHandle(Control.java:508)
at org.eclipse.swt.widgets.Composite.createHandle(Composite.java:235)
at org.eclipse.swt.widgets.ToolBar.createHandle(ToolBar.java:231)
at org.eclipse.swt.widgets.Control.createWidget(Control.java:523)
at org.eclipse.swt.widgets.Scrollable.createWidget(Scrollable.java:131)
at org.eclipse.swt.widgets.ToolBar.createWidget(ToolBar.java:331)
at org.eclipse.swt.widgets.Control.(Control.java:98)
at org.eclipse.swt.widgets.Scrollable.(Scrollable.java:72)
at org.eclipse.swt.widgets.Composite.(Composite.java:93)
at org.eclipse.swt.widgets.ToolBar.(ToolBar.java:98)
at org.eclipse.jface.action.ToolBarManager.createControl(ToolBarManager.java:99)
at org.eclipse.jface.action.ToolBarContributionItem.fill(ToolBarContributionItem.java:190)
at org.eclipse.jface.action.CoolBarManager.update(CoolBarManager.java:912)
at org.eclipse.ui.internal.WorkbenchWindow.updateActionBars(WorkbenchWindow.java:2644)
at org.eclipse.ui.internal.WorkbenchWindow.largeUpdateEnd(WorkbenchWindow.java:2693)
at org.eclipse.ui.internal.Workbench.largeUpdateEnd(Workbench.java:2684)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2328)
at org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPage.java:2317)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.java:2303)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:69)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2298)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2283)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:384)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:347)
at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileAction.java:98)
at org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystemEditorAction.java:98)
at org.eclipse.ui.views.navigator.OpenActionGroup.runDefaultAction(OpenActionGroup.java:120)
at org.eclipse.ui.views.navigator.MainActionGroup.runDefaultAction(MainActionGroup.java:327)
at org.eclipse.ui.views.navigator.ResourceNavigator.handleOpen(ResourceNavigator.java:673)
at org.eclipse.ui.views.navigator.ResourceNavigator$6.open(ResourceNavigator.java:432)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:780)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:816)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:148)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:778)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1009)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1108)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:244)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:239)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:278)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:925)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3287)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:2907)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:1899)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1863)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:417)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplication.java:106)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:99)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:92)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:374)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:169)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338)
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Dialog open exception:
java.lang.OutOfMemoryError: Java heap space
when a project is opened and closed again and again in my added plugin environment i am getting this error…please help…
