Mem: 1G
SDE
Machine OS: WinXP
Eclipse: 3.1
Recently installed the Evaluation version of SDE.
SDE is a great product but I have experienced several times (at least 5 times in two days) when my entire machine seems to degrade performance…to a standstill. I am usually forced to bring up the task manager and end the process. This usually costs me anywhere from 5-10 minutes of aggravation, plus the loss of any unsaved work.
The most recent hang was while reverse engineering a database to ER.
Note: the CPU usage is pegged at 100% while this hang process occurs.
It seems unpredictable. I am not able to easily reproduce the situation.
Below are the contents of vp.log as it is still hanging:
[ Mon Jul 11 08:59:49 GMT-07:00 2005]: Start Smart Development Environment Enterprise Edition for Eclipse [SDE EE-EC]: 3.0 (20050624a)
cannot call load_setCodeSignature(..) here
Dummy Synchronize Info is being used
java.lang.IllegalStateException
at org.eclipse.jface.text.projection.ProjectionMapping.toImageLine(ProjectionMapping.java:478)
at org.eclipse.jface.text.TextViewer.modelLine2WidgetLine(TextViewer.java:4745)
at org.eclipse.jface.text.source.ChangeRulerColumn.doPaint1(ChangeRulerColumn.java:397)
at org.eclipse.jface.text.source.ChangeRulerColumn.doubleBufferPaint(ChangeRulerColumn.java:262)
at org.eclipse.jface.text.source.ChangeRulerColumn.access$4(ChangeRulerColumn.java:237)
at org.eclipse.jface.text.source.ChangeRulerColumn$1.paintControl(ChangeRulerColumn.java:184)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:83)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:852)
at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:1153)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3090)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3706)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:1656)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:2711)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.block(ModalContext.java:153)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:303)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:447)
at v.lcy.i(:16)
at v.qnf.f(:166)
at v.qnf.f(:151)
at v.mat.r(:562)
at v.pvo.t(:616)
at v.pvo.f(:594)
at v.gbt.f(:70)
at v.h.n(:442)
at v.h.f(:421)
at v.nzt.i(:177)
at v.nzt.i(:189)
at v.nzt.i(:27)
at v.qiz.propertyChanged(:42)
at org.eclipse.ui.part.WorkbenchPart.firePropertyChange(WorkbenchPart.java:122)
at org.eclipse.ui.texteditor.AbstractTextEditor.firePropertyChange(AbstractTextEditor.java:4951)
at org.eclipse.ui.texteditor.AbstractTextEditor$3.run(AbstractTextEditor.java:319)
at org.eclipse.ui.texteditor.AbstractTextEditor$ElementStateListener.execute(AbstractTextEditor.java:464)
at org.eclipse.ui.texteditor.AbstractTextEditor$ElementStateListener.elementDirtyStateChanged(AbstractTextEditor.java:322)
at org.eclipse.ui.editors.text.TextFileDocumentProvider$FileBufferListener.dirtyStateChanged(TextFileDocumentProvider.java:271)
at org.eclipse.core.internal.filebuffers.TextFileBufferManager$3.run(TextFileBufferManager.java:374)
at org.eclipse.core.internal.runtime.InternalPlatform.run(InternalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at org.eclipse.core.internal.filebuffers.TextFileBufferManager.fireDirtyStateChanged(TextFileBufferManager.java:372)
at org.eclipse.core.internal.filebuffers.ResourceTextFileBuffer$DocumentListener.documentChanged(ResourceTextFileBuffer.java:64)
at org.eclipse.jface.text.AbstractDocument.doFireDocumentChanged2(AbstractDocument.java:724)
at org.eclipse.jface.text.AbstractDocument.doFireDocumentChanged(AbstractDocument.java:687)
at org.eclipse.jface.text.AbstractDocument.doFireDocumentChanged(AbstractDocument.java:672)
at org.eclipse.jface.text.AbstractDocument.fireDocumentChanged(AbstractDocument.java:749)
at org.eclipse.jface.text.AbstractDocument.replace(AbstractDocument.java:1104)
at org.eclipse.jdt.internal.ui.javaeditor.PartiallySynchronizedDocument.replace(PartiallySynchronizedDocument.java:111)
at org.eclipse.jface.text.DefaultUndoManager$TextCommand.undoTextChange(DefaultUndoManager.java:147)
at org.eclipse.jface.text.DefaultUndoManager$TextCommand.undo(DefaultUndoManager.java:261)
at org.eclipse.core.commands.operations.DefaultOperationHistory.doUndo(DefaultOperationHistory.java:417)
at org.eclipse.core.commands.operations.DefaultOperationHistory.undo(DefaultOperationHistory.java:1253)
at org.eclipse.ui.operations.UndoActionHandler.runCommand(UndoActionHandler.java:64)
at org.eclipse.ui.operations.OperationHistoryActionHandler$4.run(OperationHistoryActionHandler.java:239)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:291)
at org.eclipse.ui.internal.operations.TimeTriggeredProgressMonitorDialog.access$6(TimeTriggeredProgressMonitorDialog.java:1)
at org.eclipse.ui.internal.operations.TimeTriggeredProgressMonitorDialog$2.run(TimeTriggeredProgressMonitorDialog.java:201)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:69)
at org.eclipse.ui.internal.operations.TimeTriggeredProgressMonitorDialog.run(TimeTriggeredProgressMonitorDialog.java:213)
at org.eclipse.ui.operations.OperationHistoryActionHandler.run(OperationHistoryActionHandler.java:248)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996)
at org.eclipse.ui.commands.ActionHandler.execute(ActionHandler.java:182)
at org.eclipse.ui.internal.handlers.LegacyHandlerWrapper.execute(LegacyHandlerWrapper.java:108)
at org.eclipse.core.commands.Command.execute(Command.java:311)
at org.eclipse.core.commands.ParameterizedCommand.execute(ParameterizedCommand.java:396)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeCommand(WorkbenchKeyboard.java:459)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(WorkbenchKeyboard.java:781)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEvent(WorkbenchKeyboard.java:828)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequenceBindings(WorkbenchKeyboard.java:550)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$3(WorkbenchKeyboard.java:493)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard$KeyDownFilter.handleEvent(WorkbenchKeyboard.java:117)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:917)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:880)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:876)
at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1190)
at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:3135)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3038)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplication.java:103)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:226)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:376)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:163)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334)
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Can't load JDBC Driver
java.sql.SQLException: Io exception: Invalid connection string format, a valid format is: "host:port:sid"
at oracle.jdbc.dbaccess.DBError.throwSqlException(DBError.java:134)
at oracle.jdbc.dbaccess.DBError.throwSqlException(DBError.java:179)
at oracle.jdbc.dbaccess.DBError.throwSqlException(DBError.java:333)
at oracle.jdbc.driver.OracleConnection.<init>(OracleConnection.java:404)
at oracle.jdbc.driver.OracleDriver.getConnectionInstance(OracleDriver.java:468)
at oracle.jdbc.driver.OracleDriver.connect(OracleDriver.java:314)
at v.kxz.connect(:30)
at java.sql.DriverManager.getConnection(DriverManager.java:525)
at java.sql.DriverManager.getConnection(DriverManager.java:171)
at v.uds.i(:436)
at v.sn.actionPerformed(:405)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1849)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2169)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:420)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:258)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:234)
at java.awt.Component.processMouseEvent(Component.java:5488)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3093)
at java.awt.Component.processEvent(Component.java:5253)
at java.awt.Container.processEvent(Container.java:1966)
at java.awt.Component.dispatchEventImpl(Component.java:3955)
at java.awt.Container.dispatchEventImpl(Container.java:2024)
at java.awt.Component.dispatchEvent(Component.java:3803)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4212)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3892)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3822)
at java.awt.Container.dispatchEventImpl(Container.java:2010)
at java.awt.Window.dispatchEventImpl(Window.java:1774)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:463)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:242)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:163)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:153)
at java.awt.Dialog$1.run(Dialog.java:515)
at java.awt.Dialog.show(Dialog.java:536)
at v.rzi.show(Unknown Source)
at v.qgd.i(Unknown Source)
at v.bj.i(:148)
at v.qgd.show(Unknown Source)
at v.sea.i(:19)
at v.xxz.i(:24)
at v.euv.n(:68)
at v.uvn.u(:173)
at v.vkn.F(:213)
at com.vp.vpsde.ec.actions.ORMReverseDatabaseAction$1.run(:18)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:461)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:157)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:149)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
This is a show-stopper for us. We are currently evaluating VP and several other competing products. So far, I like VP, but this situation does not help.
Please advise :?
