Eclipse stuck at startup with VP
Hi everyone
I need Eclipse and Visual Paradigm for UML 9.0 for school.
I installed both of them with the JAVA JDK and did the IDE integration with Eclipse after installation.
Now when I try opening a Workspace with Projects with Diagrams included, Eclipse gets stuck and eventually stops responding.
After closing the loading screen I get an error message.
See attachments for the screens.
Does anybody have experience with this problem?
Is it a common problem?
Opening Eclipse with a normal Workspace (just Java code Projects) worked, but once I tried opening a Diagram project and closed it in Moddeling mode it didn’t start up for both kind of projects.
I hope you guys can help me.
NGDM
EDIT: I’m using JDK 7u10.
I had to reinstall Windows 8 so I had a chance to try again on a fresh system but still got the same issue. Must be something with the way they work together.
Hello NGDM,
From your screenshot it didn’t tell what version of JDK you are using. May I know what is your JDK version?
Rain Wong
Hi Rain,
The latest version, 7u10 I think.
It is version 7u10 as mentioned in the edit.
The newest. 7u10 I think.
Hello NGDM,
Can you try to launch your eclipse with JDK 1.6 and see is it work?
Rain Wong
[quote=Rain]Hello NGDM,
Rain Wong[/quote]
Do you mean JDK 6u1?
Can’t find the 1.6, link please?
Hello NGDM,
Yes.
Rain Wong
I tried with JDK 6u1 but then Eclipse couldn’t find the JDK.
So I tried using a previous version of the JDK 7u6 but it still gets stuck.
I really need an answer or solution asap because I need those two programs to work as I have exams coming up and I can’t study without them working :frowning:
Hello NGDM,
Please modify the eclipse.ini to specify eclipse using your JDK 6u1 to start and see is it work? You can follow the link below about how to specify the JVM location with the eclipse.ini.
http://wiki.eclipse.org/Eclipse.ini
Rain Wong
Sorry for the late answer.
In the meantime I have had my exams and I noticed that Eclipse does work with VP IF I don’t close a Eclipse+VP session with the moddeling view open.
So after manipulating the diagrams I have to switch back to Java Perspective before closing Eclipse.
If I do this, restarting Eclipse does work, else it gives the same error as described above.
I’ll try your solution now.
I have the very same problem and I also need VP for school, here’s the entire error log…
!SESSION 2013-02-16 12:44:22.943 -----------------------------------------------
eclipse.buildId=M20120914-1800
java.version=1.7.0_13
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product
This is a continuation of log file C:\Users\Username\Documents\Eclipse\workspace.metadata.bak_0.log
Created Time: 2013-02-16 12:45:03.456
!ENTRY org.eclipse.osgi 2 0 2013-02-16 12:45:03.456
!MESSAGE While loading class “v.zmo”, thread “Thread[main,6,main]” timed out waiting (5008ms) for thread “Thread[Worker-0,5,main]” to finish starting bundle “com.vp.vpsde.ec_6.2.1 [793]”. To avoid deadlock, thread “Thread[main,6,main]” is proceeding but “v.zmo” may not be fully initialized.
!STACK 0
org.osgi.framework.BundleException: State change in progress for bundle “reference:file:plugins/com.vp.sde.eclipse_5.1.0.0/” by thread “Worker-0”.
at org.eclipse.osgi.framework.internal.core.AbstractBundle.beginStateChange(AbstractBundle.java:1088)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:298)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:464)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
at v.cpvt.init(:61)
at org.eclipse.ui.part.ViewPart.init(ViewPart.java:122)
at org.eclipse.ui.internal.ViewReference.initialize(ViewReference.java:144)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:288)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:859)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:839)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:111)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:319)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:240)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:161)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:141)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:896)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:630)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:518)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:503)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:74)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:732)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:703)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:697)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:682)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1114)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:98)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:646)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:59)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:642)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:59)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:639)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:968)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Caused by: org.eclipse.osgi.framework.internal.core.AbstractBundle$BundleStatusException
… 120 more
Root exception:
at v.cpvt.init(:61)
I get this problem with VP for UML 9.0 by the way.
Recently I found out that our school also offers the 10.0 version, so I tried it with that one and now it works like a charm.
I’m guessing this could be because of a compatibility problem with Windows 8 or something!
So Anonymous, maybe you could try that if you can?
Thanks for the help anyways
