Hello - Looking at the 5.2 Enterprise edtion VP-UML tool. When I create a ERD there is no way to pin the connectors to the entity side that I would like. They are always on the either side (top or bottom is not an option) and I can’t control which is higher than another. As a result the diagrams are very messy and hard to read. If I create 2 entities without fields I can pin the connector where ever desired but once I add columns I can no longer do this. Is there an option that I a missing somewhere to allow me to control this?
Yes, you could turn this behavior off by right-clicking on the diagram and select Presentation Options | Point Foreign Key End to Associated Column from the popup menu.
Would you mind sending me the project file and the log file (%VP-Suite_HOME%/bin/vp.log) for testing? You can reach me personally at: jick@visual-paradigm.com
[quote=nw60312]Hello - Looking at the 5.2 Enterprise edtion VP-UML tool. When I create a ERD there is no way to pin the connectors to the entity side that I would like. They are always on the either side (top or bottom is not an option) and I can’t control which is higher than another. As a result the diagrams are very messy and hard to read. If I create 2 entities without fields I can pin the connector where ever desired but once I add columns I can no longer do this. Is there an option that I a missing somewhere to allow me to control this?
