Anyone know where they are read from or how i can add / edit them? I need to add some types for a SQL database which don’t seem to be in there. I’ve looked in the data type definitions in options but none of them listed seem to be what is getting used for the ERDs
Hi Edwardlynn,
Thanks for your post. Please go to Tools > Object-Relational Mapping (ORM) > Database Configuration and set SQL as default database, then you will be able to select data types for SQL.
Please be reminded that Database Configuration is supported in VP-UML/SDE Professional Edition (or above) and Database Visual Architect (DB-VA).
