I’m trying to install Community Edition of Visual Paradigm but I have Java exception error.
I did try also the free trial edition, same problem. I’m on Windows 10 Pro.
Here are the logs :
Exception:
java.awt.AWTError: Assistive Technology not found: com.sun.java.accessibility.AccessBridge
at java.desktop/java.awt.Toolkit.newAWTError(Toolkit.java:472)
at java.desktop/java.awt.Toolkit.fallbackToLoadClassForAT(Toolkit.java:488)
at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.accept(ForEachOps.java:183)
at java.base/java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:177)
at java.base/java.util.HashMap$KeySpliterator.forEachRemaining(HashMap.java:1603)
at java.base/java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:484)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474)
at java.base/java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:150)
at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:173)
at java.base/java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
at java.base/java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:497)
at java.desktop/java.awt.Toolkit.loadAssistiveTechnologies(Toolkit.java:532)
at java.desktop/java.awt.Toolkit.getDefaultToolkit(Toolkit.java:613)
at java.desktop/java.awt.EventQueue.invokeAndWait(EventQueue.java:1342)
at java.desktop/javax.swing.SwingUtilities.invokeAndWait(SwingUtilities.java:1480)
at com.install4j.runtime.installer.Installer.getScreenExecutor(Installer.java:92)
at com.install4j.runtime.installer.Installer.runInProcess(Installer.java:57)
at com.install4j.runtime.installer.Installer.main(Installer.java:45)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at com.exe4j.runtime.LauncherEngine.launch(LauncherEngine.java:85)
at com.exe4j.runtime.WinLauncher.main(WinLauncher.java:94)
at com.install4j.runtime.launcher.WinLauncher.main(WinLauncher.java:25)
Caused by: java.lang.ClassNotFoundException: com.sun.java.accessibility.AccessBridge
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:581)
at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:178)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:521)
at java.base/java.lang.Class.forName0(Native Method)
at java.base/java.lang.Class.forName(Class.java:398)
at java.desktop/java.awt.Toolkit.fallbackToLoadClassForAT(Toolkit.java:485)
… 23 more
System properties:
sun.desktop=windows
awt.toolkit=sun.awt.windows.WToolkit
java.specification.version=11
sun.cpu.isalist=amd64
sun.jnu.encoding=Cp1252
java.class.path=C:\Users\matth\AppData\Local\Temp\e4jFA15.tmp_dir1580039848\i4jruntime.jar;C:\Users\matth\AppData\Local\Temp\e4jFA15.tmp_dir1580039848\user.jar
sun.awt.enableExtraMouseButtons=true
java.vm.vendor=Oracle Corporation
sun.arch.data.model=64
install4j.exeDir=C:\Users\matth\Downloads
user.variant=
java.vendor.url=http://java.oracle.com/
user.timezone=Europe/Paris
user.country.format=FR
os.name=Windows 10
java.vm.specification.version=11
user.country=US
sun.boot.library.path=c:\users\matth\appdata\local\temp\e4jfa15.tmp_dir1580039848\jre\bin
sun.java.command=C:\Users\matth\Downloads\Visual_Paradigm_CE_16_1_20200108_Win64 (1).exe
jdk.debug=release
sun.cpu.endian=little
user.home=C:\Users\matth
exe4j.unextractedPosition=75934889
user.language=en
java.specification.vendor=Oracle Corporation
java.version.date=2019-10-15
java.home=c:\users\matth\appdata\local\temp\e4jfa15.tmp_dir1580039848\jre
javax.accessibility.assistive_technologies=com.sun.java.accessibility.AccessBridge
file.separator=
java.vm.compressedOopsMode=Zero based
line.separator=
java.specification.name=Java Platform API Specification
java.vm.specification.vendor=Oracle Corporation
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
exe4j.moduleName=C:\Users\matth\Downloads\Visual_Paradigm_CE_16_1_20200108_Win64 (1).exe
exe4j.tempDir=C:\Users\matth\AppData\Local\Temp\e4jFA15.tmp_dir1580039848
javax.accessibility.screen_magnifier_present=true
user.script=
exe4j.consoleCodepage=cp0
sun.management.compiler=HotSpot 64-Bit Tiered Compilers
exe4j.isInstall4j=true
java.runtime.version=11.0.5+10-LTS
user.name=matth
path.separator=;
os.version=10.0
java.runtime.name=Java™ SE Runtime Environment
sun.java2d.noddraw=true
file.encoding=Cp1252
java.vm.name=Java HotSpot™ 64-Bit Server VM
java.vendor.version=18.9
exe4j.semaphoreName=Local\c:users_matth_downloads_visual_paradigm_ce_16_1_20200108_win64(1).exe
install4j.appDir=C:\Users\matth\AppData\Local\Temp
java.vendor.url.bug=http://bugreport.java.com/bugreport/
java.io.tmpdir=C:\Users\matth\AppData\Local\Temp
java.version=11.0.5
user.dir=C:\Users\matth\AppData\Local\Temp\e4jFA15.tmp_dir1580039848
os.arch=amd64
java.vm.specification.name=Java Virtual Machine Specification
java.awt.printerjob=sun.awt.windows.WPrinterJob
user.language.format=fr
sun.os.patch.level=
java.library.path=C:\Users\matth\AppData\Local\Temp\e4jFA15.tmp_dir1580039848\user;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Windows\System32\OpenSSH;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\Program Files\Git\cmd;C:\Program Files\TortoiseSVN\bin;C:\Program Files\nodejs;C:\Users\matth\AppData\Local\Microsoft\WindowsApps;C:\Users\matth\AppData\Local\GitHubDesktop\bin;C:\Users\matth\AppData\Local\atom\bin;C:\Users\matth\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\matth\AppData\Roaming\npm;c:\users\matth\appdata\local\temp\e4jfa15.tmp_dir1580039848\jre\bin
java.vendor=Oracle Corporation
java.vm.info=mixed mode
java.vm.version=11.0.5+10-LTS
sun.io.unicode.encoding=UnicodeLittle
java.class.version=55.0
exe4j.launchName=C:\Users\matth\Downloads\Visual_Paradigm_CE_16_1_20200108_Win64 (1).exe
Thanks for your help
