i use vp-uml ee, it work properly in windows xp, but when i install on windows vista i found error “The jvm could not be started. The main method may have thrown anexception.”
Could anyone help me?
Hi Kunakon,
Thanks for your post. If you enabled user Access Control on Vista, please try to right-click on the launcher of VP-UML and select Run as Administrator in the popup menu.
Alternatively, please start VP-UML and disable Auto Update at Tools > Options > General > Update (select “Never”). After that, restarting VP-UML should not have the same error again.
Then when you want to check whether there is update of product, you can run “VP Suite Update” inside VPSuite/bin folder to check.
Hope this helps. Please feel free to contact me if there is any further inquiry.
Hola, a mi me da el mismo error en Windows XP.
¿Puede alguien ayudarme??
Gracias
